So Wonder Watt is generally working really well for us.
Where it's falling down is the solar forecast.
This is for 2 reasons:
1) Although I've got 4.95kWp of panels, my inverter is limited to 3.68kW.
2) I've got 11 panels facing WNW and 7 panels facing SSW
I've just changed my Wonderwatt settings to West and 4.95kW to see if that helps.
Anyone else have any suggestions?
Also I wonder if Wonderwatt could change to use Solcast or something similar (although even that wouldn't be perfect due to my split array on one inverter). Or pick the forecast up from GivEnergy, which I have just set up to use Solcast - be interesting to see how accurate it is - I've used the same settings, but told Solcast that inverter is limited to 3.68kW
