I have a WW rule that runs 12:00-14:00 that says if the SOC is above 90%, export down to 75%. It triggered today. However this is what my inverter log showed:
The commands in the red box above had no business running at that time! They should have run at 13:05! The WW rule triggered, and ran the correct commands using ref O59HmiQk. However, almost two minutes later, commands 0HlLCPuH turned them off again! So my export did not take place.
What the heck?
Looks like that was due to one of the previous export schedules end instructions (overridden erroneously from yesterday!) - which was due to end at 12:00.
I checked your export schedules now and they all look good, and are spaced out enough so this will not cause an issue again tomorrow.
We can't bear a 'Day 4 of WW erroring' thread! 😜
    admin Crossed fingers Thursday behaves!
    Thanks, the explanation makes sense. Am not sure there was anything I could have done to ensure the command that borked yesterday was wiped off your system though?
      miffy Am not sure there was anything I could have done to ensure the command that borked yesterday was wiped off your system though?
      No, there wasn't, it's our fault, we should have cleared out those entries.
        I was extremely tempted to create a "Day 4 of WW erroring" thread for a laugh.. but chickened out!
        Seriously though, all was well on Thursday and so far today. Cheers.
