admin the inverter has a max throughput of 3.6, in the advanced setting I have it set at 3.5.
The battery max throughput is different. It is quoted as max 2.5, but until the recent updates from Paul L at GivEnergy it always peaked at 2.42 in both directions which is why it is set at 2.4 in your advanced settings. Now the max is different for import vs export. This is a stated improvement from GivEnergy in this release for us on gen1 hybrids as well as faster response time on gen1 hybrid model produced after a certain date, in my case it can be nearly 2.9 now for export, subject to temperature.
The actual on the GivEnergy app for export is then confirmed by the figures from the octopus mini as well (see screenshots).
But this may only be a possible reason for my exports finishing early than expected. I have exports set through to 19.00. Without hitting the minimum soc remaining, the export is not utilising the full flux window for export and then possibly (if not enough solar) leaving me, without eco reset (which still occurs at 19:00), importing at the high flux price. When you are setting the discharge your setting you are sending through do not set the window stop to 19:00 as per the settings of my schedule on wonderwatt. Yesterday you sent the stop for 18:44.
(At the moment I have now disabled my schedule on WW, so as to hold any logs that may be required).
