rjp Disabling a charge schedule and/or setting the number of slots to zero didn't switch the inverter out of 'timed charge' mode, so the following day timed charging happened based on the previous day's slots. Is this expected behaviour?
admin rjp Yep - it is expected behaviour, unless you temporarily pause your schedules (which will disable schedules on inverter) and enable again - which will leave the inverter settings alone.
