Matt1976 My export schedule for tonight hasn't been set up and no note in the activity log. impressive-ride
admin Matt1976 Your current export is running, right? The export you set up from 18:00-18:59 won't kick off until closer to 18:00. Also - you may want to start it at 18:05 or so, so it doesn't overlap with the finish of the previous one.
Matt1976 its running, but only because it manually set it to do so in the Growatt dashboard, as you can see from the logs nothing has been added today.
admin Matt1976 Looks like we had a few DB issues this afternoon, should all be resolved now. Might have led to others seeing some disruption too.
