  • WW rule did not run today, for no obvious reason
[palatable-district]
Hi. Every day I discharge to the grid at 4pm. It's in my schedule, which is set to On:
Everything about the rule was true
and at 4pm my battery was at 96%.
Unfortunately, WW has totally ignored the rule. Here is the Activity Log
And here is the inverter log
Why didn't the rule run, AND why didn't it even attempt to run? WW has acted as if the rule didn't even exist!
    Yeah, apologies, we were struggling with some intermittent DB issues this afternoon, all sorted now though.
    miffy exactly the same for me too, my battery nicely at 98% ready to take advantage of the optimum export window
    I was going to ask about toggling the discharge rate switch as today I had toggled it to run at 100% rather than the 'current discharge rate'. I'm assuming this made no difference and the db issues you mentioned are the culprit and why we've missed out on exporting £3+ worth again today?
    Are any further db issues expected, and is it possible to be warned so we can possibly intervene manually?
