MrMessy Tested both discharge and charge.
30min discharge worked perfectly. Only niggle I noticed was on the WW portal it stayed showing "stop" after the end time and I had to press this to get back to a point where I could choose another option (no screenshot unfortunately).
Thanks - found this bug, wasn't affecting Growatt.
We'll make the Quick Schedule functionality publicly available shortly.
MrMessy Quick charge failed. All commands were sent as expected but, as we thought, it doesn't disable the "pause charge" option I have enabled.
It would need a command to change this to "not paused" at the start and then revert back at the end.
Makes sense, this will take us a bit of time, as we will need to introduce our settings snapshot mechanism.
Do you know which API setting this is for Unpausing and Pausing the battery? I also think this may be different for different gen inverters and FW, which will be a bit of a pain.
