A query please - Why does GivEnergy battery switch itself off after charging to 100% using wonder watt is there’s setting I’ve missed thanks
Battery switches itself off
Slight-cow
My nightly routine is battery set to charge on octopus 11.30 till 5.30 ,eddi heats water for a hour, all has of late been ok but it’s only when battery charges to 100% it seems to switch itself off
I did a fixed charge a while ago to 100% and it did it then so that’s why I use the smart charge but last night it did it again for some reason
Thanks for looking at my settings no doubt it’s something I have/ haven’t set correctly
SueEdmond Nothing at our end suggests any failures or weird settings at the end of your charge slot 5:30.
Can you go to the GivEnergy web dashboard, click on My Inverter on left hand side nav, then from the top right hand menu, click Remote Control.
And scroll all the way down to the bottom for the Logs, and could you screen shot that in here please?
And when you say 'switched off' - do you mean the battery is not discharging? Have you got the Eco mode enabled on your Giv inverter?
Remote Control History
Search
Time
2024-10-01 10:57:46
User
You
Register
Enable DC Discharge
Message
Written Successfully
Raw Previous Value
1
Raw Value Sent
0
Raw Response
0
Via
Mobile app presets - Eco
Time
2024-10-01 10:57:46
User
You
Register
Enable Eco Mode
Message
Raw Previous Value
0
Raw Value Sent
1
Raw Response
1
Via
Time
2024-10-01 10:57:04
User
You
Register
Enable DC Discharge
Message
Raw Previous Value
0
Raw Value Sent
1
Raw Response
1
Via
Time
2024-10-01 10:57:03
User
You
Register
Enable Eco Mode
Message
Raw Previous Value
1
Raw Value Sent
0
Raw Response
0
Via
Time
2024-10-01 07:18:49
User
You
Register
AC Charge 1 End Time
Message
Raw Previous Value
747
Raw Value Sent
0
Raw Response
0
Via
API - Inverter Settings - Wonder Watt - blNJWRyA
Time
2024-10-01 07:18:47
User
You
Register
AC Charge 1 Start Time
Message
Raw Previous Value
717
Raw Value Sent
0
Raw Response
0
Via
Time
2024-10-01 07:17:54
User
You
Register
Message
Raw Previous Value
0
Raw Value Sent
717
Raw Response
717
Via
API - Inverter Settings - Wonder Watt - q5HRRQG1
Time
2024-10-01 07:17:54
User
You
Register
Message
Raw Previous Value
0
Raw Value Sent
747
Raw Response
747
Via
Time
2024-10-01 05:28:03
User
You
Register
Message
Raw Previous Value
530
Raw Value Sent
0
Raw Response
0
Via
API - Inverter Settings - Wonder Watt - ooLkN57n
Time
2024-10-01 05:28:03
User
You
Register
Battery Charge Power
Message
Raw Previous Value
20
Raw Value Sent
50
Raw Response
50
Via
Time
2024-10-01 05:28:02
User
You
Register
Message
Raw Previous Value
2330
Raw Value Sent
0
Raw Response
0
Via
Time
2024-10-01 05:28:01
User
You
Register
Message
Read Successfully
Raw Previous Value
16
Raw Value Sent
Raw Response
20
Via
Time
2024-09-30 23:28:58
User
You
Register
Message
Raw Previous Value
50
Raw Value Sent
16
Raw Response
16
Via
API - Inverter Settings - Wonder Watt - CbCrzQfA
Time
2024-09-30 23:28:57
User
You
Register
Message
Raw Previous Value
0
Raw Value Sent
2330
Raw Response
2330
Via
Time
2024-09-30 23:28:57
User
You
Register
Message
Raw Previous Value
0
Raw Value Sent
530
Raw Response
530
Via
Yes giv energy setting on eco
Thanks for your patience and help to sort issue much appreciated
The lights on the front are out so I have to push button on side to switch it back on then my dashboard displays charge level of battery etc and all is good again I have 3 batteries 2 x2.6 kw and 1 x9.5 kw it’s just the 9.5 that seems to go off
Yeah think your right I’ll give giv energy a call
Thanks
