NellieC Looks like a inverter communication/connection failure (well, if I'm interpreting "inv_set_lost" correctly. See logs below.
Can you verify your inverter serial in Settings is correct (at least the part you can see)? If not, please click Connect, see if it refreshes and then Save the settings.
