So having a few funny charge slots on Intelligent Octopus since the clock change.
Saturday night we had a slot 23:30 - 04:30. Then an extra couple of slots before 06:30 (which might have been valid allocations from Octopus).
Then last night we had a slot booked from 22:30 - 04:30. So not only did battery charge when it was expensive for an hour last night, but it went from 100% to 71% before 05:30 as we have everything using power during the cheap rate.
Watt ID is: recent-cake
Clock change issues?
admin looks like I'm still having this issue? I'm still using the one hour charging schedule that @MrMessy suggested which sets charging back on at 04:30 to 05:30, but as you can see the IO charge seems to be ending at 04.30.. Unless it's the schedule I've set which is upsetting things. I will try switching that schedule off tonight..
