KristianS Again, many thanks Kristian.
Glad you are enjoying the chess.
Taking all things into consideration, I am now very tempted to move from Agile to IOG.
As you say, we can keep the EV fully charged overnight (at 7p/kWh) and also max out the AiO battery (to 13.5 kW). We can also time-shift some other appliances (which we do try to do with Agile) W/M, TD and Dishwasher to use the overnight rate.
Even looking at tonight’s Agile slots, the lowest is still above 11p/kWh.
We can then also run the ASHP 24/7 and not have to have it timed out between 16:00 and 19:00 hrs.
I think my only question is how does WW and IOG work together? You say that you use the ‘intelligent page’ - I assume this is within the WW APP?
On another (hopefully interesting) topic. The EV we have just bought is the KIA EV3 - which I believe is capable of V2G/V2H (but not yet enabled in the UK). Our EV home charger is currently the GivEnergy one, but I believe Zappi will be bringing out a bi-directional A/C EV charger later next year. The thought being that the battery in the EV3 (approx 80 kW) could act as a second source of power to the home via V2H and may mitigate the need for a 2nd AiO.
