ALLENPATTRICK
The problem persists and no messages on activity log ,
On 26/11 2 slots were selected for 2130 and 2330 and neither were run and neither produced activity log messages. I expected the 2130 one to fail as it fell below the start SOC level but the schedule was not logged.
This morning there was no activity when the 0000 (hold) Schedule should have started. I then tried to restart the schedule a little later but without success. I later tried to run my DAY schedule which does not use the Hood facility and this also failed to run. I then deactivated all schedules and manually set off a 4 hour charge at 0115 from Growatt interface which seems to be running ok.
Grateful if you would check again. It appears to have upset my ability to run any schedules whether hold or not. Please let me know when I can run WW again. I am quite prepared to avoid the periods between 2300-0000 or hold off using Hold while you are hunting down the cause. I will disable the Growatt command later this morning to avoid it being run again. You may delete it if is at all likely to interfere with WW.
Many thanks
Many thanks
