I set up my account to work with GivEnergy and it seemed fine.
My trial ended without me knowing and of course schedules stopped working. We also had the installer come out to replace a bit of hardware.
I subscribed, and created a new GivEnergy API token. I pasted it in and clicked connect and it said connected successfully.
But on the home page I now get
Error loading energy flow data: Error accessing data - check API key [B51xUxmG]
I am not sure the schedules are working either?
    Doylie I bet you forgot to Save at the bottom of settings after connecting? ๐Ÿ˜œ
    Thanks for the sub. ๐Ÿ™Œ
      admin Well, I feel a tadge daft now! Thanks for the heads up, that worked perfectly.
        Doylie Good stuff, youโ€™re not the first user this happened to, perhaps we should detect that this is an API key update and if successfully connected, save automatically.
        Hey there,
        Thanks for this. One thing that I am noticing now is the scheduled charging isn't kicking in. When I press the Quick Schedule it works, but the scheduled charging doesn't seem to kick in?
        To test I created a short scheduled charge to happen, and it certainly didn't! There wasn't anything in the activity log either?
        I wiped all the schedules and started again but it didn't help?
          Doylie Make sure you leave a buffer of 5-6 mins or so from when you set it up to when it should start. The custom charge scheduler runs every 4 mins.
          So if you set a charge schedule up 2 or 3 mins from when it should start, it could get missed.
          Thanks, I have just set it for 10 minutes time. Fingers crossed!
