dj10gan Hi, I had charge slots scheduled for 10:30, 11:30 and 12:00 which were ignored? I couldn't see a reason for this. I have missed something?
admin dj10gan I can't see any 10:30, 11:30 or 12:00 charge slots in your selection? Did you select these slots in the morning and save them? Your 14 Agile charge slots for your 00:00-16:00 were all ran for a long charge from 00:00 - 07:00.
dj10gan That could be the case, but I was pretty sure. If there is a slot activated and the battery is full will the app export to the Grid if there is no load required? Thanks for the help.
kerregan dj10gan The inverter can’t import and export (nor charge and discharge the battery) at the same time. If the battery is full, anything your solar panels produce in excess of your self-consumption will be exported.
