Hi, new sign up here as still in debate whether i can warrant the time and money to set up HA, WW looks a great alternative
Im using a Growatt 6kw inverter with 2 growatt batteries totalling 13 kwh
The discharge rate i have when on 100% is 4kw however when they charge its only 2.6kw , i note in the advanced settings that its a single box for battery rate and one for inverter rate. How can i set this up so that WW knows i can charge at 2.6kw but discharge at 4kw - although im not sure i need to as i have everything set up as when on IOG slot, charge, when approaching 23:30, check charge level and discharge if above x, so probably wont impact anything.
