Hi,
Occasionally (once every month or so I reckon), I find that the battery hasn't been discharging fully - normally 137W/4% max rate. This does mean I'm using peak rate prices rather than the stored battery.
Happened again yesterday PM - I managed to fix (albeit after the peak period) by going into the GE app and ensuring the battery discharge max was put back to 2.6kW.
I couldn't seen anything obvious in the logs that was changing the setting down to 137W (or about 4% I think it was), but I'm guessing it is to do with the hold charge instruction having an issue and not properly releasing?
limp-catch
