I am using the IOG integration, The 'Home' dashboard shows today's and tomorrows solar forecast; would it be possible to display tonight's forecast charge? That figure must be in the system somewhere.
Thanks
John
    At the moment 'm setting a 'floor' charge of 50% so I get at least that, but it would be nice to see what WW is planning to put in. I think 50% (of 16.4kWh) is soon going to be way too much on most days.
    Ta
      gwynnej3 I think I've mentioned this previously, but if your on IOG with fixed export, it makes no financial sense to undercharge your batteries. Just set them to always charge to 100%, then all solar not self consumed gets exported at 15p/kWh.
      If you want to finesse things further for more profit, you can dump any excess left in your batteries at the end of the day, and/or set your batteries to not use solar.
        MrMessy
        I am testing dumping on a evening and waiting for the sun to recharge rather than paying 7p
        This is more complicated for me as I have 12kw panels
        12kwh battery
        But can only export 3.68kw into grid
        So clipping is a big issue for me
          MrMessy I'm on Feed In Tariff, so I get the same 77p/kWh generated whether I export anything or nothing. I'd still like to know what the system was proposing to charge in any case.
          MrMessy with fixed export, it makes no financial sense to undercharge your batteries. Just set them to always charge to 100%, then all solar not self consumed gets exported at 15p/kWh.
          That's what I ended up doing on Agile. As long as the overnight charge rate is below the fixed price export rate, I might as well fully charge the battery overnight and export the solar.
          I think we've gone off-topic now...
          The other thing I'm trying to understand is in today's portal (Home) it shows solar forecasts as 12 and 8.7 for today and tomorrow respectively.
          If I download today's solar forecast csv from the Activity Log page, that has 11.4 and 9.1 kWh.
          Which figures are actually used?
          I ask because I'm comparing forecast and actual numbers...
          Thanks again :-)
            gwynnej3 The values get updated at 11AM and 11PM. Values used would be close to realtime whenever a decision is made related to solar yield (that you see in the activity log).
