PeteC
2025-05-17 23:32:11 100 % 23.1 kWh
Charge instruction set for IOG 23:30 - 05:30: 100% target at charge rate of 10%
For your example, it looks like your battery was already at a SOC of 100%, our IOG instruction was simply set to 'charge' to the current level. I.e. keep as is. So in this case, you were simply pulling from the grid at around 7p IOG offpeak, rather than using battery.
Always look at what the battery SOC was at the point of our charge instruction and see what the delta is to target SOC we sent, which in this case was actually 0. 😉
With IOG, our main strategy is to not have the solar battery drain into the car.
Hope that makes sense.
