Hi,
Tried all of the above but no success.
I tried an experiment and I changed the amps from 30 to 15.
Not surprisingly, the forced charge halved to .72 KWH. I then looked at the Solax numbers through Solax Cloud and the charge number had dropped to 1.5 amps (10% of the WW number as seen before). I then raised the amps to 32 and the inverter went to 3.2.
I then changed the Solax inverter setting (via Solax cloud) back to 30 and set WW to 30.
12:05hrs The battery charged at over 7kwh for a few minutes but, just now, the forced charge has stopped (c15 mins into a 45 minute session).
12:14 hrs. I have restarted the forced charge and noticed the Solax cloud amps have dropped again from 30 to 3, and the battery is charging at 1.44 kwh.
regards,
