roadsport7 Hi. Octopus bump charge appears to be overwriting the inverter force charge time. This means that peak electricity is being used rather than battery. It also means that the inverter needs to be reset each time. Regards
admin roadsport7 That's been sorted for quite a while now. Weather This was specifically related to Intelligent Octopus Go tariff. Where Wonder Watt would not distinguish between smart cheap slots vs boost slots, but has long been rectified.
Weather Hi roadsport, did you find more hints to your question and what do you mean exactly with the reset need? Just posted another query related to Octopus and Flex tarifs. So an update of your post would be appreciated. BR FW
