I know I am like a broken record, but not being able to record an Inverter Discharge Rate, In addition to an Inverter Charge rate is a real pain for me. Unless I am charging my EV and house batteries simultaneously, I run @ full chat 24/7 in and out.
My Inverter Rate and Battery rate are 12kWh in and out, but my DNO Inverter discharge rate is limited to 9.5kWh. I am finding the limited choice in standard scheduling between 100% and Advanced (Settings rates), is a limiting factor, and not being able to record my real Inverter discharge rate for WW to make accurate time adjustments when necessary is a real pain.
Before the fix was put in place for the correct portal command for controlling Inverter / Battery power on dual AIO's I had one of the advanced rates set to 9.5kWh. That worked because the Power Command that got sent to my inverter made no difference, and WW adjusted times accurately when necessary.
So can we get a solution for this sorted please? I am not the only one asking for this feature @KristianS
