admin Yep - the question is, would those custom rates take precedence over the global rates?
I have a few thoughts as usual,
Are we still going to get a separate Inverter Rate for Export in Advanced Settings?
My Inverter Rate is set to 12kWh in advanced but my DNO export Rate is 9.5kWh. If I want to charge at full rate 12kWh then I have the Inverter Rate in Advanced settings set to 12kWh. However with the Inverter rate set @12kWh WW makes incorrect calculations for "adjusted" End Times on Export Schedules because of my DNO limit for Export is 9.5kWh but WW thinks I am exporting at @12kWh, there is no way around this unless there is a setting in advanced for both Inverter Charge Rate and Inverter Discharge Rate.
As it stands we have an Inverter rate for each system which is dual purpose both for Charge and Discharge, why not add in Advanced settings a Discharge Inverter Rate (as discussed above). These two rates are then the Maximum Global Rates for both Charge and Discharge. Then In Advanced Settings, allow users to create say 5 Charge and Discharge Rates which can be named similar to this. The Watts will be calculated as a percentage of the Individual Global Charge and Discharge Rates defined in Advanced Settings.
Then in the Scheduler, if the Schedule is a charge Schedule and the user selects "Adjust Charge Rate" the Charge / Discharge Rates Menu would be displayed for the user to Select from as below.
If the Schedule is a Discharge Schedule and the user selects "Use Current Discharge Rate then the user can choose the required rate from the popup menu of available rates.
The system described above would if implemented solve the long standing issue of the missing Inverter Discharge Rate, providing accurate WW calculated adjusted end times and allow user defined Charge / Discharge Rates to be applied to any Charge or Discharge Schedule.
