gwaring Will i need to change the time on the inverter & Eddi when the clocks go back?
Should be automatic. I've never had to change the time on my Zappi.
For the Giv inverter, it seems quite common for installers to get the wrong time zone when commissioning. I had to correct mine but, it's been fine since.
gwaring What would the best electric tariff be for winter based on my set up - I have a worcester gas boiler for heating and hot water.
Yeah, tricky one. Octopus, or any other supplier for that matter, don't seem to have a great battery tariff for winter.
So, it depends on your attitude to risk. Agile is the obvious candidate with WW, as there's plenty of support on here.
Alternatively (and switch off your moral compass for this bit), Octopus Go, standard version not Intelligent.
The T&Cs are a bit ambiguous, and if you sign up online, it's just some boxes to tick.
Besides, how is charging a home battery at 3kW different to charging a PHEV at 3.5kW?
