Obiwan Looking at the log it looks like some slots were skipped because it was at 100% but I didn’t want it to discharge during those slots. If that makes sense?
Makes perfect sense.
By default, WW will skip an Agile charge slot if the battery SOC is 100%. I have situations where I want the charge slot actioned even when the battery SOC% is 100% mainly to stop battery discharge.
While WW work on an option to have this feature as an on/off advanced setting, there is a workround using the Agile window SOC% Less Than field. If you enter 101% in this field, then the charge slot will be actioned even if the battery SOC% is 100%.
This does mean that manually selected slots outside an Agile window can't use this feature (hence the need for an advanced setting) but you can create a dummy Agile window to cover slots not in a window and just set the SOC less than field.
Here is my example:
Note: Don't forget to activate the window for it to work 😉
