I tried charging the battery using Wonder Watt last night, but it didn't happen. Luckily I set the alarm to wake me at 3am to check on it, so I was able to turn on the battery charge using the GivEnergy portal instead. It had been unchecked for this test.
Picture below are the settings I used, Enable Smart Charge WAS ticked. I turned it off when used portal to charge battery instead.
I left Use Battery unticked. Do these settings look right?
