I have been getting some peak schedules for IOG charging and making the most of the additional charge. However, when I unplug my car I've noticed that the charging of the battery can go beyond the 30 buffer.
For example I unplug the car at 8.03. but looking at the activity report the check to see the API update hasn't happened and it's 8.40 and the battery is still charging.
The last check was 7.42pm .. and I'm wondering if the check happens every 30 mins at a rolling rate and not every 30 mins on the hour and on the half hour.
What I'm thinking should happen is the IOG API should be pinged every 30 mins (.30 and 1hr slots) and not every 30 mins from the point of charging starting.
I cannot see how to stop the charge manually either.
I've tried to change the intelligent setting to HOLD but again I don't think the app is checking for this change often enough.
Hope that makes sense?
UPDATE... MY BATTERY Continues to charge about 1hr after the IOG stopped and I cannot stop the battery charging!!! This is costing me a lot of money right now ... Probably losing any value of paying for a subscription to the app!
