ALLENPATTRICK Glad to hear it has the desired effect. As previously mentioned, this is only a temporary workaround until WW get their own fix deployed to stop the export and revert the changes once the target SOC is reached.
It will take a few runs to fine tune the schedules to your exact setup and requirements, but there should be no need to adjust the power output. I may have misunderstood your query as I see no power parameter on the export schedule. WW are looking at two export options, maybe user selectable if they are both implemented:
- Reached target SOC at full power and then stop before export end time
- Reduce the power output to spread the export over the whole scheduled period and end at the scheduled export time.
Both options should have the desired effect of preventing the export finishing early and drawing from the grid for the remainder of the schedule, but the option that is best for you will be whether you want to finish export early and start using your battery, or holding off using the battery until the end of the export schedule. Remember that the export schedule will export both to the grid and to your home at same time so I prefer option 1 as it will always have the desired effect and never draw from the grid when you don't want it to. Option 2 relies upon getting the export power set right to ensure you export what you want whist still supplying home demand in the scheduled export period. If the export power is too high or your home demand drops then the target SOC could be reached too early and still draw from the grid for the remainder of the schedule. If the export power is too low or your home demand increases then you may not reach the target SOC for export that you set.
These are just my thoughts and I'm sure WW will be looking into this in greater detail than what I have to ensure both GE and Growatt batteries are controlled accordingly.
