admin I was having a play with Export today as it was a suitable solar day. I'd already tried one session and decided to run another one, almost straight away, so I may well have missed the problem I had when the second one finished.
When the second session finished it kept on importing from the grid. It just looked as if ECO hadn't kicked in but it was showing as Enabled. Tried disabling/re-enabling it - made no difference so I did a 'Reset to Defaults' and reset.
The one thing in the log that looked odd to me was the top two, I expected 'Enable DC Discharge' to be after ' Enable ECO' in the list. i.e. enabling ECO being the last thing done.
07/01/24 16:28 You Enable DC Discharge Written Successfully TRUE FALSE FALSE API - Inverter Presets
07/01/24 16:28 You Enable Eco Mode Written Successfully FALSE TRUE TRUE API - Inverter Presets
07/01/24 15:25 You Enable DC Discharge Written Successfully FALSE TRUE TRUE API - Inverter Presets
07/01/24 15:25 You DC Discharge 1 End Time Written Successfully 14:30:00 16:30:00 16:30:00 API - Inverter Presets
07/01/24 15:25 You DC Discharge 1 Start Time Written Successfully 14:00:00 15:30:00 15:30:00 API - Inverter Presets
07/01/24 15:25 You Enable Eco Mode Written Successfully TRUE FALSE FALSE API - Inverter Presets
As it's too cold for the golf course tomorrow, I'll try again then...
