Gazzagreen Nothing in the inverter logs?
Agile Octopus integration
We'll keep an eye on it for when it starts to get warmer. ATM it doesn't matter, I am just exporting because of the saving session.
Gazzagreen Instructions were successfully sent.
Can you show the Giv logs? Did another cmd get sent after that once it was discharging?
Where do i get these logs from?
I did accidentally put charge on instead of export manually when thumbling with the mobile LOL
Gazzagreen Looks like on your inverter we may need to explicitly set Eco mode to off as well, judging from the Giv app's instructions for Discharge...
Gazzagreen Should be sorted now as part of release 343.
Hello,
Same as @Gazzagreen here too. I set up the export in good time and was monitoring what my setup was doing using the excellent " Inverter " app from bbcbasic.co.uk which I have running permanently on an old iPad that I keep on the sideboard. I gave it a few minutes after 18:00 to see if it would kick in, then I set it up to start at 18:10 using the Givenergy cloud.
Deleted
KevinD Right, but unlike with @Gazzagreen - it doesn't look like we sent any discharge instruction. Was the SOC value condition met? And how many mins in advance did you set it up? Was it 1 min away, or say 5?
Export function runs every 5 mins, could be that because you set it up so close to it being ran, it was missed out.
We'll look through some logs too. Update: can't find a discharge instruction, so that sort of confirms this is a due to the interval.
We will have a look and see if we can bring that interval for export checks down a bit. Regular charging scheduler checks every 4 mins by the way.
I set the export schedule up at about 13:30
I can help you test it tomorrow if you need, I'm in and out all day though as I do a delivery job in the mornings and out to family dinner in the afternoon. But I am about now and then while waiting for a job on the app. Don't mind setting up some exports for 5 minutes or so. See if we can get it to start and finish correctly. It has worked in past so will be something small.
Gazzagreen great, thanks Gazza!
another random one, can you tell why my 0530 slot didn't activate last night? I had a big block of charge from 0200-0500 then a gap then one more scheduled for 0530-0600 but no instruction was sent for that last 30 min slot that I can see on the activity log.
