Evening discharge schedules didn't take place
Same with me. I set a manual discharge but this stopped after 5 minutes
WW user id spiffy-point
Same here. Scheduled discharge slots didn't work, nothing showing in WW activity log and no instructions sent to Giv Inverter
open-departure
...some other exports do however seem to have failed at our end.
And can't push temp fix currently because of:
Update: Looks like some of the battery reserve read cmds for Giv inverters failed in some cases, which led to some exports not being run. We've put a fix in that shouldn't stop the discharge from going ahead if the read fails.
JayC the answer can be found in our FAQ: https://community.wonderwatt.com/d/5-wonder-watt-faq
admin Ooo the frustration of having to wait to get home to get off the phone and be able to CTRL+F and find it.
For the curious out there the answer is "Based on target stop SOC, current SOC and max discharge, we set the export end time to be the expected/adjusted end and revert back to Eco-mode"
JayC Thanks!
Another thread here too, discussing this - where you pointed out it was working for you.
https://community.wonderwatt.com/d/239-export-to-grid-adjusted/4
