Lins1 export schedules not working suggests you've paused them here:
https://app.wonderwatt.com/pause
or, they're not "active" here:
https://app.wonderwatt.com/schedules
If your battery isn't powering the house at all, first check you have "Eco on export" set to on here:
https://app.wonderwatt.com/advanced
then, in the Giv web portal, go to My Inverter, ⚙️, and refresh each register. Eco is near the top. You may have inadvertently switched Eco off, or they can get stuck, particularly when playing around with the app.
I would refresh every register whilst you're there, and check they all make sense.
