admin Doesn't help at all I'm afraid, what WW does it does very well by the look of it, the downside is unneccessary maximum charge rate time.
What I'm suggesting in the short term is that the user has the ability to set the 'Global Charge setting' from within WW twice a day, once to set a night-time setting and once to set a day-time one. In my case to achieve 80% from zero over my TOU period all I need is a charge rate of 1680W, however that is no good for daytime use at the moment where I need the 3000W charge rate to maximise solar capture.
True, in the longer term a more dynamic 'Charge Setting' based on the battery %, solar forecast and the target % would be even better. In the meantime I'll need to pursuade my poor old grey cells to remember to do it manually twice a day!
