In a Timed discharge sequence this morning the Battery Reserve % Limit got set to 20%
2024-01-13 11:58:28 You Battery Reserve % Limit Written Successfully 20 4 4 API - Inverter Settings
2024-01-13 11:58:27 You Enable Eco Mode Written Successfully false true true API - Inverter Presets
2024-01-13 11:58:27 You Battery Reserve % Limit Written Successfully 50 20 20 API - Inverter Presets
2024-01-13 11:58:26 You Enable DC Discharge Written Successfully true false false API - Inverter Presets
2024-01-13 11:58:26 You DC Discharge 1 End Time Written Successfully 12:00 00:01 00:01 API - Inverter Presets
2024-01-13 11:58:25 You DC Discharge 1 Start Time Written Successfully 10:30 00:00 00:00 API - Inverter Presets
2024-01-13 10:25:05 You Battery Reserve % Limit Written Successfully 4 50 50 API - Inverter Presets
2024-01-13 10:25:05 You Enable DC Discharge Written Successfully false true true API - Inverter Presets
2024-01-13 10:25:04 You DC Discharge 1 End Time Written Successfully 00:01 12:00 12:00 API - Inverter Presets
2024-01-13 10:25:03 You DC Discharge 1 Start Time Written Successfully 00:00 10:30 10:30 API - Inverter Presets
2024-01-13 10:25:03 You Enable Eco Mode Written Successfully true false false API - Inverter Presets
I would have expected it to go to 4%. which it tried to do after the Enable ECO
