KateAyres Sadly, still getting the same message: 'An error has occurred. This application may no longer respond until reloaded.'
admin KateAyres Can you please try this again and @Jorrit could you try the same? Whilst you might get the same error, we built some more detailed logging and diagnostics in, which will allow us to troubleshoot the problem better. Thank you!
Jorrit admin hi admin , it seems it now connects , so a step further .. but I now have the issue the it says my TLX version not (yet) supported.
KenNeedham Hi Just found your website and am having same issue as the others Growatt's server seems to be a bit flaky at the best of times, I've had problems in the past trying to connect with my own custom software
admin Jorrit Ah OK, yeah, support for Growatt TL-X inverters is something that we will be rolling out this week.
admin Gr8scot OK, thanks - it's a known issue which we are working on to resolve. This is tricky due to the undocumented nature of the Growatt APIs.
yolandahh Hi, I am having the same issue. Every time I try to connect to with my growatt username and password I get an error saying "An error has occurred. This application may no longer respond until reloaded". Could someone help me please?
admin yolandahh Must be an issue with incorrect username or password, please login with Growatt username/password in https://server.growatt.com/login to make sure it is correct, thanks.
ChrisS Not sure why I didn't get a reply before but I'm getting the same error as yolandahh and my username and password are able to login to Growatt directly.
admin ChrisS Can you DM or email ( labs@wonderwatt.com ) us your Growatt username please so we can try and locate this in the log files for troubleshooting? @yolandahh Thanks!
admin Thanks for reporting, issue can be reproduced and a fix is being rolled out now. Should be live in the next 10 mins. Updated: Now fixed in Release 855.
