admin I have turned off the Schedule to see if it works tonight :)
No Battery charge for me last night
admin If it doesn’t work tonight, I’ll try using a new API key.
Gazzagreen That doesn't seem to be an issue in all fairness for you, as we'd expect a different error. But yeah, let us know what happens tonight.
@Gazzagreen & @admin It looks like I had the same problem !! https://community.wonderwatt.com/d/565-battery-was-stopped-from-charging-last-night
Hi, I have had the same issue with no over night battery charging for almost a week.
I went in to my GE account and had to add the over night time schedule in to the settings as it had all been cleared.
Hopefully the update will correct the charging issues too. Will see tonight.
I also have an issue on my WW home screen where I get the prompt: Error loading energy flow data and to check the API key.
I have updated both my GE and IOG APIs in WW and still get the error prompt. Any ideas?
tuckenby Sounds like an incorrect Giv API key. To test your API key before using it and updating it in Settings, you can follow these instructions here:
https://community.wonderwatt.com/d/541-home-page-not-working/8
My Battery charged as normal last night. Seems turning off the WW schedule worked when using IOG, which automatically sets it’s own schedule.
Oh looks like you put a fix out (813) that may have been the solution?
Gazzagreen Oh looks like you put a fix out (813) that may have been the solution?
Yep, that's the one. Glad it worked OK for you.
