admin ah wait here’s something. Looks like time was changed by Wonderwatt.
Intelligent Octopus Go - limited beta
extraneous-pattern Great, thanks for digging that out.
So it looks like a mapped charge slot was issued for 18:51-04:00 by Octopus, and we picked up the 04:00 AM end charge.
We need to add a fix where if the end time for a mapped charge is within the main IOG offpeak window, we extend it to 05:30 by default.
I had the same problem that drained my battery again. What happened is that I plugged in the car at 02.43am when the schedule was already set. Octopus added slots all the time up to 6.30am and then from 09.30-11.00. What happened though is that the 02.43-6.30 slot got to WW but didn't work. I had it in the activity log but between 5.30 and 6.30 it didn't work and my battery charged the car. Then the 9.30-11.00 slot worked fine. It seems that the 23.30-5.30 had some priority over the 02.00-06.30
angellevski Right, the issue is that the 23:30-05:30 instruction had already been sent and is set on the inverter.
We need to consider how slots that start within the default IOG window and extend are dealt with.
admin great thanks. I had same issue again last night so might be worth looking. Battery was 49% this morning instead of 100%. Car charging ended within the IOG time slot which was until 0400. Battery started draining at 0400 again instead of 0530. Immersion kicked in at 0415 and drained battery.
extraneous-pattern Hopefully should be addressed in Release 694.
https://community.wonderwatt.com/d/96-wonder-watt-release-notes
Could I join the IOG beta please. Thanks
@admin
Have a minor issue with last night's charging.....
Smart charging from Octopus 23:00-05:30 and 05:30-06:00
WW picked up the slots and initially set 23:00-06:00, but subsequently overwrote with 23:30-05:30
As it turns out, the EV had finished charging at 05:15 anyway, so didn't cause an issue with battery drain, but it would have, had the Octopus EV charge continued.
Could you have a look at this please?
As a sidenote, is there a reason the charge commands are not sent until after the charge period is scheduled to start?
WW-ID:primary-hotel
Hello,
Thank you for letting me join WW. My first EV is being delivered next month. Are you still accepting new participants and is it best to wait to join this project until I swap tariffs to IOG?
violet-local
Thank you
